I have 2 x 51.2v LFP batteries connected via Busbar to Growatt SPF5000ES.
I want to check if I am using the correct wire sizes. Currently I'm using 2 AWG (33.6 mm2) rated for 188A.
I am about to add a Class T fuse between Busbar and the Inverter and realised the total potential is 200A, I got a class T fuse rated for 250A.
Question is that, should I also be upgrading the wires from Busbar to the inverter as the current wires are rated for 188A? Is that right?
