Insulation Stripper?
HRTKD
Boondocker
Staff member
Moderator
Somewhere South of Denver
More than once I hacked my way past the insulation and removed a few strands of wire. A utility knife isn't the best tool.
I have an old Weidmuller Stripax that is excellent. But I don't think it will do 6 awg and certainly not 2/0. It did work on 10 awg PV wire. The insulation on my TEMCo 6, 1 and 2/0 cable is EPDM. Any recommendations on a stripper for larger gauge cables?
I saw the one that Will used in his videos, but the reviews on those types of strippers seem terrible. The Greenlee 1903 stripper has mixed reviews in one page and lousy in another. Their more expensive adjustable stripper has even worse reviews.
I have purchased a Jokari Wire Stripper and will be using that for the first time in a couple of days. It has got to be better than a utility knife, which I have been using.
I’d like feedback on that if someone has used one.
I looked at the Jokari before I posted. Based on the specs, 2/0 would be at the margin of it's range, if not completely outside it.
For any wire thicker than 8 awg I use a Fiskars by pass pruning shears. Something like these;
Please tell me you’re joking. Getting decent information about working with thicker than 10 gauge is difficult. I’m sure it has lead to some very questionable DIY installations because of some of the bad info.
THere’s some “end of the internet things,” searches that google does just not review a lot of results easily. One is dealing with wires thicker than 10 gauge. I’ve yet to find what seems a proper tool, although the hydraulic crimpers I have seem a whole lot better idea than the hammer a crimp. I would think a list of proper crimping devices by lug type would be not too hard to find, but I can’t seem to find a list.
Same thing with wire strippers. At a job I used to work, we had proper tools for that, but did not deal with stripping and crimping those thick wires too much, and its been 26 years since I left that field.
I see many posts that crimping is better than soldering and that done correct, the copper strands in the wire fuse together. I read in one of Trojan’s white paper on batteries that the best way to make a battery connnector is to crimp and solder. They had an IR picture that showed the temps and the coolest connection was both soldered and crimped.
Throw this on top of what you get off the internet is not what’s advertised. One crimp tool I have is metric, not AWG, but the manufacturer relabaled the pieces 2/0, 1/0, etc.. without actually making the correct size, so I need to go one smaller when I use that set.
I use the jokari or the fiskar shears. Both work well if you take your time. I have a nice crimper so usually have no problems
The fiskar shears that I use to prune my plants in my backyard can be used for a wire stripper?
The Jokari works well on welding cable and ok on xhhw, not good for thhn.
Yes the fiskar shears are great. Take your time with them and when they get dull replacement shears are cheap. Adapt and overcome ?
The Jokari works well on welding cable and ok on xhhw, not good for thhn. If the joker doesn't work well, I will a utility knife.
I will be using it mostly for the welding cable, 2/0. For the thhn I will be cutting, it is 6 gauge and 7 strand, so pretty stout.
This just goes against everything I would think about using a proper tool. I really thing a utility knife would be better than pruning shears. Who would have known.
It does go against everything i have been taught as well. However it is consistent with, necessity is the mother of invention. Or, don't let perfect be the enemy of good.
My toolbox is littered with redundant tools I bought when I had only misplaced the missing tool.
I was on a quest yesterday and went spelunking into the far corners of the Internet for cable strippers. Either I entered just the right search terms or I have my browser locked down because I didn't get any porn results.
Some of the more interesting cable strippers that I found are listed below. All of them may need to be configured to your wire. The knives can be adjusted for the thickness of the insulation.
Dewalt DCE151TD1 20V MAX* XR® CORDLESS CABLE STRIPPER KIT
It's an all-in-one kit that can strip 6 AWG to 750 MCM CU and 900 MCM AL. The quick connect bushings in the kit are designed to fit different cable sizes. It's a slick kit in my opinion. With a depth gauge on the collar, it's easy to get consistent, predictable strip depths. A good portion of the time I spent stripping insulation is measuring the depth. This tool would have saved me a lot of time.
At $326 on Amazon, this is a very expensive cable stripper. But it sure is cool!
Ripley Tools WS 68 & WS 68 SNAP Series
This is the same tool in the Dewalt kit, but without the drill part. Purchase the collar and then the specific bushings you need for the wires to be stripped. Ripley offers straight cut and chamfer cut bushings, while Dewalt only provides straight cut. The Ripley bushings should fit the Dewalt.
Pricing is challenging. There aren't many retail sites that sell this. On TechToolSupply.com, the collar tool is $240, then you have to purchase individual bushings for around $90 each. However, their selection is limited to only two bushings! 3/0 and 4/0. At that price, the Dewalt kit is a bargain.
Ripley 4x4 Plus Series
Ripley sells a manual tool that uses the same bushings. It holds four bushings. $157 at J Harlen.
Klein Large Cable Stripper 21051
Klein makes a tool similar to the Ripley 4x4. I haven't found the bushings for it. I read that they are not fixed (they're interchangeable). A bargain at $55.
Jonard Tools CST-1900 Round Cable Stripper
Strips cable 3/16” to 1 1/8” (4.5 mm to 29 mm) in diameter. That covers the size of cable I was looking to strip. It says it can strip rubber insulation which was what brought this tool up on my radar. It looked promising and I almost bought it. But the reviews prevented me from going through with it. There were a lot of positive reviews, but the very pointed negative reviews held me back. $41 on Amazon. The CST-4000 works on even larger cable.
The way I use the utility knife is to roll the wire across the blade. I try to avoid cutting with the blade so that I don't cut into the strands. This works well, but is time consuming. I do end up with some ragged ends.
On the bright side, it hardly matters how many strands you lose stripping insulation.
The ampacity of copper is far higher than the tables list - those are just for heat dissipation and temperature rise from a long wire with insulation.
If your copper wire necked down to 1/2 or 1/4 its cross-sectional area where it entered the terminal, that section would dissipate more watts per inch, but the heat escapes into the long wire and then out through insulation. So long as the twisted strands have electrical contact, current will spread out as soon as it can.
A 1 mil wirebond can carry up to about 1A at room temperature; that is about where it burns out, depending on how long it is.
2/0 wire has 130,000 times the cross section of that wirebond, but we normally only put 200A or so through it.
(I guess that means no concern at about my utility drop carrying 100,000A fault current so long as I use a class-T fuse and not just my 200A main breaker which is rated 22 kA interrupting.)
