Has anyone had problems with their chargery DCC disconnecting without an alarm on the BMS?
I have 16 eve 280ah batteries mounted under my rv connected to an 16t bms with 600 amp shunt and DCC. Twice the DCC has cutout while all the cell voltages and temperatures are in in the acceptable range. (3.3v and 35c) . I have also checked the cell difference voltage, temperatures difference settings and charge limits. It will be a couple days limping home before I can pull the battery pack and get back to the BMS to see what signal is being sent.
It seemed to work fine on the bench but now the solar is charging it at 45 amps on solar vs 2amp of my benchtop supply.
