fire hazard
- Jul 14, 2021
- 160
4 12v gel batteries 51ah 2s/2p can someone help me with a bms 24v total,i noticed one battery was charging at 15v
i need help guys what do i need to balance charge these batteries4 12v gel batteries 51ah 2s/2p can someone help me with a bms 24v total,i noticed one battery was charging at 15v
Do you have a diagram or pic of how your batteries are wired? Are they wired in a balanced way or all from one battery?i noticed one battery was charging at 15v
would i need 2Looks like you need not a BMS but just a battery equalizer. Something like this one - https://www.amazon.com/PowMr-Battery-Equalizer-Voltage-Balancer/dp/B07L8XKZ71/
thankyou i think that would work i posted some pics,your thoughtsLooks like you need not a BMS but just a battery equalizer. Something like this one - https://www.amazon.com/PowMr-Battery-Equalizer-Voltage-Balancer/dp/B07L8XKZ71/
connected in series on the outside parallel in the middleHappen to have a pic that shows all the battery wiring?
will that battery equilizer work with my battery config,just one or 2Happen to have a pic that shows all the battery wiring?
aligator clips are from inverter,they will be gone soon,yeah voltage fluctuates on all four batteries,sun goes down all batteries rest at 12.9,so will that equalizer work with my setupI don't know why but that wiring makes my head hurt. I "think" its a good wiring setup.
Whats up with the alligator clips? Whats that for?
What kinds of battery voltages are you seeing at a high Soc and a low Soc? Same battery(s) high and low?
One battery always high another always low?
I have never used one, i have all LiFePO4 now.will that equalizer work with my setup
