oldmancharlie
- Aug 21, 2021
- 12
Hey everyone,
I just posted a few annoying question laden posts in a couple other sections, I'm a total noob with PV systems, and wanted to hopefully add something back to the community!
This is for cold-climate folks, the colder the better this works. If you're in a cabin with a woodstove roaring and temperatures down to -20 to -50 C, a lot of air is leaving up your stove pipe, and so your cabin sucks it in from every crack it can find... around windows, doors, holes in your vapour barrier, you name it. This all contributes to a cold, drafty cabin.
The simple and elegant solution is to put an intentional cold air intake and have it come in under or next to your woodstove. 4" ducting, placed high enough so rodents can't get to it, screened for bugs and regulated with a damper does just fine. Now when it's super cold and your fire is going, with the damper open, fresh air is drawn in through here, and so it doesn't try to squeeze in from every crack. The cold air is warmed by your stove so you get fresh warm air instead!
Hope this helps someone out there! I live on the same latitude as Anchorage, AK, have done, seen, been told or read about all sorts of cold-weather tips and tricks, for houses and vehicles; if anyone ever has anything they are struggling with let me know
All the best out there,
Charles.
Charles.
