Can you touch the panel while you are on the ground? If you feel some juice flow through you, then you need to bond/earth the array.
The most confusing term used is grounding.
You are a lot more resistant to the flow of energy than a grounding rod and a copper grounding wire. If there is a bonded grounded rod, the electricity always goes to the path of least resistance.
