Tracks added as in you can/do use it to record some of your trips?@Mike Jordan I believe there is a ui config option to make it run the screen. I've only used mine headless.
@Dzl The GPS populates the dashboard and there are some tracks added there as well.
You can also add some alarm based rules using longitude and latitude so that if it changes you'll get an alarm event (emails in my case)
