All these comments about "unvaccinated cause mutations" OR "vaccinated do not spread covid at nearly the rate of unvacinated" OR "vaccination will stop covid" or "masks are required to stop spred" and on and on and on - are not actually based on 'science' but rather conflations of data points, junk-science, journalistic/political agendas, and time lines. For example - when newly vaccinated the efficacy is reported at 90+% but after several months it's much less - so people argue that 90% of hospitalizations are unvaccinated BUT.... over time this changes dramatically. Its conflating the original 90% data point as if it were true for all time.
For all of you making 'I know exactly what's happening' and 'I insist you do X because you're killing people if you don't' - I resist in the name of actual science and logic.
@Vertassium is as truthful, science based channel as I've ever seen and I offer this youtube to make the point that 'common knowledge' / 'common sense' is completely wrong in many cases. In this example, there is no statistical proof that learning styles (common sense?) actually exist and should direct education policy -
I for one, think that telling people what they must think or do is nothing short of hubris - except I guess I just did (yikes
