JedTheFed
- Mar 2, 2021
- 48
Hello everyone,
Scenario
10 KW onan generator
cerbo gx set to accept 50 amps
800 amps renogy batteries
2 multiplus 3000 wires in split phase.
400 amp t fuse
I set both inverters to charge at 120 amps the 400 amp t-fuse blows. If I set them both to 100 amps charging it seems ok. Why is this happening?
I thought it was because my solar charger was on at the same time when the first fuse blew, but it is still happening. I was bringing the power up from 62% charge and it got as far as 71% before the last fuse blew. This time it even melted the fuse holder.
Can I not use the full 240 amps charging? It seems I could do this before but can not do it recently without the fuse blowing.
Why is 240 amps charging blowing a 400 amp fuse?
Gary
Scenario
400 amp t fuse
Gary
