GamingGringo
- Jan 4, 2021
- 2
Hey guys,
So I've been using my 266Ah, 24v battery for a few nights now and I'm noticing some issues with the cells not balancing correctly.
Every night after I lose the solar power the battery starts to drain specific cells faster then others and the difference is shutting my battery off every few seconds.
To prevent this so i can sleep comfortably knowing my fridge and fan won't shut off, I've shut off the "power off" feature and just let it flash it's warning that the difference is higher than what its set.
Is that a problem?
Also, how do I prevent this without re-balancing? It's a pretty big battery that I plan on using frequently. Does anyone know if there are some settings that need to be tweaked? It seems to constantly use #5 @ #6 the most. Idk why...
Any help would be appreciated! thanks
Is that a problem?
