Ampster
Renewable Energy Hobbyist
Then have some patience, it may take a while like most packs do when new. At least you don't have a runner that is kicking off the BMS. The good news is your cell delta has already reduced by 100mv. At that rate you will be close within days. If you have an urgent need to see results you could go to custom settings briefly to enable Float now that you have the balancing start voltage adjusted.Float is actually hidden when using custom lithium.
