doodlesack
So I am looking to build this Van system and I think I have all the components I would like to use for this build. I've made a diagram just to show my thinking.
Q1 If I wire in the AC-DC charger to the shore power inlet, it automatically turn on every time its plugged in. Is it worth adding a switch, that can disconnect it, say if the battery bank was fully charged? I see no reason to have power on and a device running if it's not needed.
Q2. As the inverter has a UPS/ATS to shore power when its available, this negates the need for an separate ATS which supplys power to the fuse/breaker unit?
Q3. Let me know if you think there is anything else I should consider in this setup! Thanks!
(drawing doesn't include fuses/switches)
