Why"....Someone might have started with X panels and a charger to match, then wanted to add on. If the one can handle the load, maybe one would be better in some ways. If the two are working as needed, I am not sure there is reason to change. If one failed, the other would still provide some charge while you were waiting for replacement. A newer MPPT type charger might be one reason to "upgrade". You could keep the current ones as spares.
