wpns
Solar Joules are catch and release
That only works if they are the same length!Just the black ones, though. The red ones are required.
do you absolutely have to have an all in one? why not go with separate components? you get much better quality and you will more than likely definitely get your 20-30 years... you will pay for it, make no mistake about that.
I chose the separate components route as I wanted quality. My personnel favorite is supposedly going away after they were bought out, still researching this, but if i was going to do exactly what I did now I would simply use a victron, schneider or midnite inverter in place of the magnums I currently use.
these ones all cost more then EG4 or any of the other AIO's available out there by a lot but you get what you pay for. just my thoughts.
If you were replying to me , I meant “ device” components… not circuit board level replacement…This ^^^^ was my own motivation to build DIY battery packs - and be future proof if the inverters of next decade are a new voltage (just rearrange cells).
If I knew more about the electronics, I would love to be able to build an inverter, or a SCC from parts - but I don't have this level of knowledge/skill - or not yet. I opened up the MPP's to remove the bonding screws and learned a bit about how these units are assembled - mostly a group of electrical boards that could be changed out easily enough - if you had access to a replacement board.
But component level replacement for me would be tough, since I don't know enough about how the units work to trouble shoot isolating a problem component - unless it is burnt to a crisp and really obvious!
Components rule … in almost everything you build.. be it stereos, computers, high end weapons, PA systems , solar systems ….spare can be inserted and ur up and running in a few mins..
NO long term shutdowns…
Plus when building it , you learned how everything fits and works… and why…
Does it take more time…? Does it cost more..? Is it more work….?
YES…
Is it worth it…?
YES…..
Jus my opinion…
J.
When that “giant lightning bolt” hits, I go to my bunker, pull out my spares and replace inverters, panels, etc as needed.If you were replying to me , I meant “ device” components… not circuit board level replacement…
If ya got spares for SCC, panels , inverters , fuses, wires, breakers , have tools and plenty of resource material and know how to rig workarounds , you have lots of options…
you can’t prepare for every possibility but you can for most stuff… Plus if you own good stuff you probably won’t have too.
If ya get whacked buy a direct giant lightning bolt, just go to a comfort suites and reflect on life.
J.
I understand …When that “giant lightning bolt” hits, I go to my bunker, pull out my spares and replace inverters, panels, etc as needed.
Good to know I'm not the only one to have Wireshark as a desktop icon
I was just commenting that I "wish" I could diagnose and replace component level electronics, but currently would only feel capable of complete circuit board swaps. Maybe some big capacitors if it was super obvious (burnt) that this was the problem component, but not the tiny parts fitted to the boards, those would be beyond by current skill set. I checked with MPP one time and all the boards in the 6048's are available - for a price. {one time I zapped a comms board on one unit and got to do a learning exercise on how to find the part number, order then remove and install}If you were replying to me , I meant “ device” components… not circuit board level replacement…
J.
Ok cool… I wasn’t sure ..thought I had been unclear…and I’m in total agreement with your thoughts…I can do a few small internal part changes to gear and probably a bit more but don’t want to…it’s not what I’m trained to do.. I would rather just switch out for a spare device or bypass in someway and get the other one fixed correctly…I was just commenting that I "wish" I could diagnose and replace component level electronics, but currently would only feel capable of complete circuit board swaps. Maybe some big capacitors if it was super obvious (burnt) that this was the problem component, but not the tiny parts fitted to the boards, those would be beyond by current skill set. I checked with MPP one time and all the boards in the 6048's are available - for a price. {one time a zapped the comms board on one unit and got to do a learning exercise on how to find the part number, order then remove and install}
Maybe it's like getting a new truck - the early years are good, but then...in 3 + years..just a few tweaks.
I wish everything I owned worked as good ….
Hope not….Maybe it's like getting a new truck - the early years are good, but then...
not a big fan of chevies, but if offered I would happily take a 68-72 vette. those iron bumper years in that range always looked nice, and the engine is pretty vanilla anybody can work on one, you just need to ensure you get the correct front end parts (of the engine, water pump alternator etc.) as they use different mounting brackets and snout lengths to clear the sloping hood.Hope not….
But then I’ve had pretty good luck with cars in the last 50 years of driving.… never had many problems that I didn’t cause by stupidity…or hittin stuff ….
But then I was always pretty gentle on them ( except the vette) , serviced them often…and never let inlaws borrow them….
just got lucky I guess ….
Damn…I was Gona offer it to ya as I’m getting up in years…but mine is a 76 T-top …last year with the flat back window… I know ya won’t like it so I’m Gona offer it to the cheerleading squad over at the collage to ride in parades in…I will work payment out somehow..not a big fan of chevies, but if offered I would happily take a 68-72 vette. those iron bumper years in that range always looked nice, and the engine is pretty vanilla anybody can work on one, you just need to ensure you get the correct front end parts (of the engine, water pump alternator etc.) as they use different mounting brackets and snout lengths to clear the sloping hood.
So far I have never had the first issue to fix or repair on my whole system…in 3 + years..just a few tweaks.
Jim.
my eyesight can't handle anything smaller than board level these days.Heck, I'm an EE, and the most I'd do is board-level swap stuff.
Getting long in the tooth, as they say, I ain't got time for that kind of stuff.
Too much like work.
I fixed a CPU once. PDP-8 had a bad TTL flip-flop on a plug-in card. Lotsa tiny cards, much wire-wrap!Much easier with schematics.
I debugged one box of an HP 8510 to the faulty IC and replaced it.
And boards I designed, I can debug.
Some I work with today have mostly discrete or mixed-signal parts, I can make sense of them.
Otherwise I'm pretty much lost after front end of power supply.
Modern stuff with multi-layer PCB, and ICs that aren't simple logic or analog, can't trace or figure out.
Stable is great, but just a friendly reminder to consider security also with stuff that is connected to the Intersewer (aka Internet).That's the thing, in inverter is just that, an inverter. It doesn't need software updates or any bloat, it's a power supply. And you can be sure if it was mainstream, software and updates would be required or things would be unstable and they'd randomly remove features you use in the next version that you didn't want to begin with.
I find a nice stable decent thing, and I stick with it.
What he saidI can buy 3+ similar sized inverters from China for the price of a Victron, Midnight Solar, Schneider, etc.
I’m paralleling a bunch of them together (a single failure won’t interrupt my electricity) and will have spares on hand.
