Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,647
If I don't win one of these, what's you bottom line on a pair of islands ? I've got 12.5 kw of panels to power up. This is full on off grid 2000 SFO house in desert. May need 4 in the end
Greg
I'm not planning on selling any (They're mine! All mine!) but I see sellers advertising for $2200 including shipping. Some have gone for $1250 plus shipping. One guy bought the older 5048 model at the auction for $500. So that gives you a range of figures to come up with an offer. I'd suggest offering an eBay seller $5000 for four. Or maybe the guy who bought two trailers and only needs the extra PV capacity would part out and sell you two.
The Sunny Island is quite robust and able to start heavy motor loads. 5750W continuous at ambient temperature, 7000W for 30 minutes, 180A AC surge current (22 kW) for a couple 60 Hz power line cycles. Two would power most reasonable house loads. As grid-backup, the 56A relays can pass up to 6.7 kW per SI to the grid. You could use either DC charge controllers (set for a battery voltage higher than SI wants) or Sunny Boys for AC coupling and back-feed the grid. With Sunny Boy you have more total AC power available while the sun shines, and more efficient conversion of PV to AC if consumed at that moment.
I have mostly transformerless Sunny Boy. They seem fine except when I ran a 3-phase pump with VFD, which may have caused Sunny Boy to throw an error. But induction motor in air conditioner runs fine off batteries and PV.
