Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,508
This makes me feel a lot better! I suppose some of my anxiety stems from the fact that I'll only have 10 hours before I'm locked out of making any changes to the grid parameters, along with the difficulty I've had finding information about the configuration options. For all I know, there may not even be an "offgrid" setting on the -41 models... Hopefully, my utility will be okay with the CA Rule 21 setting being enabled!
Oh, and that link is exactly what I had been looking for, thank you! (I had found a similar link on SMA's blog to Off-Grid Tech Info, but that link was dead)
-40 and -41 should have "off grid" or maybe called "island". I think SMA support previously told me that could be used.
Sunny Island disconnects when grid is out of spec, so utility will never see what -41 does with Rule 21 or other.
Let us know if Rule 21 frequency-watts is already there or you have to update software.
I had at one point wanted to have some Sunny Boy wired straight to grid, and have a transfer switch move them onto Sunny Island when grid was down (because Sunny Island can manage twice as much AC coupled PV as can go through 56A relay in the 120V US market.) SI was ideal for European market at 220V. But, transfer of an inverter from one AC source to another needs 5 seconds "off" time so it doesn't get connected to an out of phase AC supply, could blow it up. Now that I have more Sunny Island than I need, 2s2p x 56A relay gives me 120/240V at 112A.
Save the .pdf files. I can't find things searching by topic on SMA's site. I use Google to search for the name of the document (found at bottom of it), get the link and then I can share it. Probably you had a link to the old rev which SMA took down. Searching for similar name should find new rev number.
