With respect to my system (still on the workbench for more testing), I am limited to space on my home and need 1400 watts to supply my power needs for max house loads. However, most of the time my house load averages 500 watts throughout the day.
Because of the space limitations due to weight and shade, I have (6) 24v (rated at 39 ocv) 300-watt panels. they weigh 41 pounds each. I am using 24-volt batteries, so putting 2 panels in series will give my 2424LV MPP controller a good voltage range to regulate to run the house and charge the battery at around 28 volts.
With (3) 2 panel series, I have them in parallel where each branch puts out 7.5 amps for a total of 26 amps available to the controller. So with 60 volts and 26 amps for the controller to regulate, it has at max performance over 1500-watts to work with.
I tried other combinations of panel configuration, but with respect to voltage and current and wire sizing, the 2 series, 3 parallel worked out best for my controller. And when there is not enough power from the solar array, the battery will make up the difference, and if that still is not enough (due to low battery voltage), the Utility kicks in.
Anyway, before I actually install my system, I will check all conditions on the bench. I don't plan on installing it on the house until spring.
