It's possible your Daly needs to have the current calibrated (using Sinowealth). If it's off all the current set points will be inaccurate. I've seen the calibration so far off that it shows charge current as discharge current. When it's this far off the BMS will use the charge mosfets for discharge functions and vice versa. You'll see the CADC Gain change to reflect the differential as you calibrate. You can calibrate using either charge or discharge current. Be sure to use the proper polarity (charge pos/discharge neg) when you make your entries. I use a small bench-top regulated power supply to calibrate my Daly. Current readings on my unit are accurate to within 100mv in the 0-1a range. Around 100-150a, it's within 1-2%.
