J Joel Bettschen New Member Joined Feb 26, 2024 Messages 25 Location Switzerland Feb 27, 2024 #1 I have a 12v to 230v inverter. What is a 100w by 230v load converted to 12v?
D DJSmiley Solar Enthusiast Joined Aug 13, 2020 Messages 694 Feb 27, 2024 #2 100/12 = 8.3A Add inverter losses and you're more like 10A. If the 100W is the load with an adapter (eg a laptop) the mains load will be higher, add 10-15% if the 100W is not the load on the input side of the device
J Joel Bettschen New Member Joined Feb 26, 2024 Messages 25 Location Switzerland Feb 27, 2024 #3 thank you so much.
V Vigo Solar Wizard Joined May 26, 2022 Messages 1,557 Location San Antonio Texas Feb 27, 2024 #4 The math DJSmiley did is called Watt's Law. That's what you need to look up so you can repeat this feat ad infinitum.
