michael d
off-grid solar pilgrim
Assembly idea for you all: As I manually lifted and moved the 4 cell Lishen cells to assemble them into the 32 cell build, onto a larger base, I found they did not slide as well as I wanted. So I added a piece of the chopping mat I bought at the dollar store under each set of 4 cells connected in parallel. I put the smooth side up so the cells can be slid a bit easier. 4 cells at 5.3kg each is still 46.64 pounds plus busbars. 8 of the 4 cell packs will weigh 373.12 pounds. I bought 5/16 inch threaded rods and washers and nuts for the compression jig. This week hopefully, I will have it assembled. the Electrodacus SBMS0 arrived last week; then came the honey-do list and the holiday. I will post some pictures later.
