So, when I do get this rod in the ground, I assume I run a #6 bare wire from the Solark ground bar through the same conduit and hole to the outside for the AC disconnect.
Then out the bottom of the AC disconnect box down the wall in conduit to the dirt. From there I go under the dirt a few inches over to the new ground rod.
I run another #6 bare wire under the dirt from the new ground rod to the existing ground rod.
That's it right?
Some inverters have 2 separate grounds one for AC and one for DC but I think the Solark only has one ground bar marked with red below.
