Ok... Just figured out how to do the "Quote" thing to answer specific questions.
They have a wide range of programmable features. My only other experience is a LV5048 (also a very nice system)
Under the "Limited to Home Mode" you can identify how much you draw from the Grid. (Factory set is 50 w/h) I have adjusted mine to 150 w/h. This seems to work best for me based on my intermittent High load usage. The other 11.85 KW is available for use.
I am also running a variable speed pool pump. Over the last few months I have been learning the timing of to program my pump for best use. I have a 35,000 gallon pool ( & yes.. then is a lot of water)... I have been able to adjust the program to maximize the filtering.
Hope this helps
The Sol-Ark has some pretty advanced programming features ... and a big Dose of "PFM" (Pure F**** Magic)What fraction of your available PV production is curtailed to avoid export to grid?
Hope this helps
