SignatureSolarJames
Make DIY Solar Great Again
- Jun 26, 2020
- 122
the drawings here are really good. 2 things would be a good improvement:
-make the output panels a "main breaker" type so that you can shut off all inverters at once
-combine all the AC inputs on a similar main breaker panel before landing on a 125A breaker at the main load panel
If you use the "AC combiner" strategy on you system you will be able to manage it more effectively.
you might consider a 100-125A Bypass switch https://www.homedepot.com/p/GE-100-...ency-Power-Transfer-Switch-TC10323R/100171587 for the AC in and AC out panels, connecting your load panel to the load side, the AC out of the inverters to the Generator side and the AC in to MDLP at your house.
This will allow for easy transfer from inverter back to grid in case of maintenance, upgrade or repair in the future.
We do not do drawings but we sure do comment on them.
