I would likely build my own batteries, but I agree with you that a 12V system would be simple and easier to implement.Putting batteries in series adds problems and complexity. One bad battery with one bad cell in series ruins the whole string.
Go with 12 volts. Little doubt you already have 12 volt alternators so why not charge and run stuff wile motoring?
Even though I had to do some studying to manipulate and solar charge outside multiples of 12 I stayed with 32 volts cause that's what the boat was set up for. A/C will run off the alternators.
I got the outback 32 volt inverter starts that anchor windless fat AC motor no problem, I am sure the 12v version kicks butt too www.google.com/search?q=OutBack+FX2012
Its also a charger and has that automatic AC transfer function.
If your considering lithium then this is a non issue because even 12v is 4 cells in series. At which point loads are my biggest concern. 2000w on 12v is ~170a that's a very large expensive wire in the boat world. vs 41a (@48v) which is a very easy wire to source and run.Putting batteries in series adds problems and complexity. One bad battery with one bad cell in series ruins the whole string.
www.google.com/search?q=marine+hot+water+heater+with+heat+exchanger&tbm=ischMaybe able to heat water and take a shower
To meet your goal of AC overnight, you're looking at 1200-2000Ah at 12v. Consider how you will parallel cells or batteries.
At 12v, you will be pulling upwards up 150A for 8-12 hours. But a 3000W inverter will need to be wired for 300A. If you decide to go larger than 3000W, i don't think they are available in 12V. Cut those numbers in half for 24v.
Best to buy a 24V alternator. A big one. A 100A 24V alternator will take 5 hours to charge a 1000Ah 24v battery. A stock 12v that's current limited will take 10-12 hours to charge, assuming the A/C is left off.
Not afraid of big wire. But afraid of a 10kW inverter that is s brand I've not heard of, costs only $1300, and weighs only 25lbs. That doesn't add up.And then 24 volt starters too ? And bilge pumps and everything else
They make lots of big 12 volt inverters and they are still the cheapest
Wagan EL3748 12V 10000 Watt Power Inverter with Remote Control, 20000 Watt Surge Peak, Proline 12 Volt Power Converter for Home RV Camping Van Life Off Grid https://www.amazon.com/Wagan-3748-Black-PROLINE-WATT/dp/B01DPB7F6M
Whats a van going to do with 10000 watts ?
Anyway Megalophobia is a type of anxiety disorder in which a person experiences intense fear of large objects. Around here it always seems to focus on wire.
I don't see the big deal running a few feet of big fat wire. Compared to the price of this hobby overall an extra $100 on wire isn't much.
32V is weird, 24V is common. And 24v-12v dcdc converters are cheap.All I know is my discontinued 32 volt system is a pain because I walk into any boat store and almost all the toys on the shelf are 12v.
Oh look on sale a spot light with half a zillion candle power ! 12v. Its always like that.
You may have not heard of us, but we've been building inverters since 1991 and have been in business since 1993 here in Hayward, CA!Not afraid of big wire. But afraid of a 10kW inverter that is s brand I've not heard of, costs only $1300, and weighs only 25lbs. That doesn't add up.
10,000W is 900A at 12V. 900A fuses cost more than a dcdc converter, and you will need several.
Plus the need for an alternator that supplies 2x the amperage. Price a 200A large frame alternator?
I assume a 12v starting battery will be retained, and arguably you should use a dcdc supply even for 12v to isolate and protect your electronics. So not really any more complicated. And 24v is *much* cheaper.
JustinG from Wagan Tech. Likely your post violates forum policy but that is not my call.You may have not heard of us, but we've been building inverters since 1991 and have been in business since 1993 here in Hayward, CA!
