Free_Sun_Power
Hello. Newbie here. The timing was right and I finally justified purchasing a pair of 12 kPV EV4 inverters + an indoor EG4 PowerPro wall-mount battery + around 20 kW of Hyperion 400W panels. I am in the planning/ implementation phase currently. I purchased the 12kPV inverter over the 6000XP assuming that the 12 kPV had a better (easier) 200A panel interconnection system with full house back-up. But now I'm faced with the reality that accomplishing a whole-house backup with grid interconnect is more challenging and costly than I anticipated (mostly due to grid-feed in case of power outage). My goal in this order is: Offset my current energy use with solar; 2). Charge the battery daily to utilize that power at night (sprinklers, etc.) 3). Sell the excess power to my utility (above-and-beyond when my battery is full). My utility interconnect is in-progress (planning-stages).
However, after reading some other forums, it seems there is an easier way being floated. I tried to draw-up what I can imagine being an easier way to accomplish this task. First, the details: I have a 200A panel but according to an hour-by-hour download of my energy usage for the past year per my utility, my highest hourly average load was 5 kW. So I want to avoid a critical loads panel if possible since in case of a power outage, I can turn-off non-critical appliances at my main panel with high start-up loads to keep within the 12 kW of surge load and 8 kW continuous load. What I read is that generator interlocks are legal in the US (perhaps vary from local municipality to local municipality). So, as you can see from the attached diagram, (assuming my local municipality doesn't disallow), would such a interlock design cause issues? This would remove the need for a critical loads panel and also manual transfer switch.
