73powerstroke
So im wondering if going from 12 to 24v solves my problems.
I picked up a 24v inverter today from santan solar. Those guys are awesome.
Here's my scenario.
I have 8 santan 240w trina panels( well actually 10 now but not hooked) and currently 2 epever 40amp tracer 4210an cc with 2s2p hooked to it and a 12v battery bank.
Simple math says 240w x8 =1920w ÷14.4 v = about 133amps. My two cc will produce 40 amps each under load. I cannot get more than 80 of the 133amps obviously. But when I go to 24v shouldn't I be able to?
1920w ÷28.8v?or is it 24.8? = 66amps
So the 2 controllers need to only put out 33amps at 24v ?
I know cc says max pv array input at 12 is 520w and at 24v its about double.
I think this means I'm good?
What should my voltage be in a 24v system? Is it exactly 2x 12v system?
So I have everything hooked up and set to 24v. I'll be able to test it tomorrow.
Is there any reason 12v could be better than 24v ?
Here's my scenario.
