Just watched Will Prowse’ comparison of 12 vs. 24v systems. He had me convinced to go 24v except for a couple of things. He is opposed to charging from the engine alternator. He said there were other options but didn’t say what they are. I think using the alternator guarantees fully charged batteries at the end of a day’s drive. I plan a lithium battery system so will need a DC DC charger if I connect the alternator. Does anyone know what he is thinking for other options than just counting on the solar panels to keep the batteries charged while driving?
He said connecting more than three batteries in parallel leads to problems. if one battery starts to underperform it could lead to reduced battery life. Can anyone enlighten me on this? I originally planned four 105aH Lion Safari UT1300 LiFePo batteries in parallel but now wonder if I should go series and parallel, 2s2p, for 24 volts/210a.
As an aside, the new batteries have 1/4” lugs whereas the cables for the batteries I am removing have 5/16” lug holes. should I replace the lugs Or use them even though they are a little “sloppy”? Also, do all of the cables between the posts, be they series or parallel connected, need to be the same length for all of the baTerries?
2005 Holiday Rambler 40 PLQ Diesel Pusher
