@jeeptj12 Made me do a second look. Inverter screen shows 0: Standard; online EG4 monitor lists only numbers except for 0: EG4. Android app either shows nothing (old settings) or just lithium (new settings). Are you running 0: EG4? 1: HinaESS has performed well today, but I'll probably switch to 0 since it's the EG4 setting in at least one place
Performance today has been great. Brought in over 23kWh so far to fill up the batteries. I've got my 14KW of panels in four equal strings with two strings to each inverter. I did notice that when batts got to 98% SOC, the master inverter was pulling in 2x the solar that the secondary was until SOC got to 100% (2kw vs ~1kw; all the way down to zero charging with ~400w vs 200w). I watched a few cycles of battery charge/discharge with solar charging being pretty close per inverter at this time during these cycles. Things settled and running completely from solar unless i throw surge greater than solar on; so perfect!!! I also noticed that fans are back to their old selves (typically quiet/not running right now with ~600w of load), and the default for this firmware changed the fan characteristic from Default to New Slope on both inverters.
Thank you
@EG4TechSolutionsTeam /EG4 Team and
@Eddie_LuxPowerTek /Lux Team! I'm passing this info to my distributor too. Great Christmas present
. Let's please help
@ScrotpusGobbleBottom as I'm sure his issue/this issue probably effects DIY battery builds (which I may also be jumping into for a trailer conversion project with a 6000xp
