Johnmahon
What's Your State of Charge?
- Nov 2, 2019
- 111
Greetings… Using an LV6048 with EG4-LL 48v batteries, Can I charge the batteries using 120v with utility using AC input, but output 240v through the AC Output ports with power from the batteries/utility?
If so, does anyone know the settings? I’ve tried just about every combination in the setting options I can think of with no luck.
Also, I seem to have a ground neutral bond issue. If there is no grid/utility whatsoever, my 240v application (load) does not power on due to ground not being present. How would I ground AC Output with no ground to tie into from the grid? However, if I have AC Input connected to the utility, the 240v application recognizes the ground from the grid and everything is fine. But I won’t always have a grid to connect AC Input and would still need my 240 AC Output to receive proper grounding to run. But doing this, I cannot get the inverter to go into bypass mode, charging the batteries...
You can see how my two questions are related
To help, I have this exact setup and want to accomplish charging an electric vehicle using the configurations/equpment seen here:
Hope this makes sense
