samus250
Hi all,
I just got solar installed with a Sol-Ark 15K inverter and HomeGrid stack'd batteries. Before all this, I just used a little 3kW, 120V Honda inverter generator. During an outage, I'd simply connect it outside and switched via a transfer switch that's outside the house. Of course, no 240V appliance would work at all with this.
My solar installers connected the Sol-Ark's grid input to the output of the outside transfer switch. So if I connect my little 120V Honda generator, the Sol-Ark 15K will always see it at the Grid input. I have a transfer switch right next to the Sol-Ark for the house/load, so I could connect the house directly to the generator and free the Sol-Ark of all load. However, the Sol-Ark will always see the 120V generator at the grid input and I have no transfer switch to disconnect it completely. I haven't tried connecting my generator since I got solar installed, and don't know exactly what will happen if I do.
My question is: will anything explode or get damaged if I connect my 120V generator in this scenario?
Ideally, I wouldn't have to touch nor change any settings at all in the Sol-Ark, and the Sol-Ark simply wouldn't connect to Grid given that it's a 120V source. In case of extended multi-day outages (they happen quite a bit where I'm at), I could use the 120V generator during the daytime to free the Sol-Ark of all load and use all available sunlight to keep the HomeGrid charged as much as possible (thus helping insure uninterrupted 240V during the night even in very cloudy days). Is my idea correct, or would I have to change settings / install another transfer switch for my idea to be possible? Note: I greatly prefer not having to buy a 240V generator.
Thanks!!!
Thanks!!!
