Henk
- Feb 18, 2020
- 11
Anyone have any experience wit the 123 smart BMS from https://www.ev-power.eu/Battery-Man...-Complete-Set-4-cells-with-Bluetooth-4-0.html
I think this was fixed on the gen 3 version that just came out but I’m not for sure. I’ll let you know when I get my hands on it.No experience with it, but it looks interesting. It is pretty much scalable for any size battery.
The one thing I didn't like is there is only 1 low temp setting which will disconnect both charge and discharge .... but i think that is the way most of them are ..... have you looked at the Chargery BMS?
Do you have an ETA?I think this was fixed on the gen 3 version that just came out but I’m not for sure. I’ll let you know when I get my hands on it.
123 Smart BMS Gen 3
No I check the tracking everyday to see if it’s in the USA yet. I won’t have an eta until it’s in the states.Do you have an ETA?
I’m not sure but I’ll let you know when I find out. Try emailing support, I have asked a ton of questions and they usually get back to me within a few days. The extended module gives you an additional 4 relays to work with that are user programmable. Try reading the manual as well.I am wondering if it is necessary to have the extended module in order to configure more than 1 temperature cut-off.
The manual for the version 3 still shows only 1 low temp setpoint that disconnects both relays.I’m not sure but I’ll let you know when I find out. Try emailing support, I have asked a ton of questions and they usually get back to me within a few days. The extended module gives you an additional 4 relays to work with that are user programmable. Try reading the manual as well.
Sounds good, I had one here a few weeks ago, got it working as far as balancing and monitoring. It had an issue with the current sensing, its supposed to be a dual sensing unit, 20 to 500A, but mine would not sense anything over 10-20A, spent weeks emailing back and forth to Europe( time difference) and finally sent parts of it back to them. They have sent me new parts which should be here any day.
I also are planning to use the 2 relays on the end board for controlling all my Victron stuff. multiplus, mppt, battery protect.
Currently trying to figure out how the 2 relays can be shared to let say 3 seperate Victron components.
Other than that the bms was super easy to set up, seemed to work really well, cant wait to get it back on to my 800Ah liefepo4 battery.
Let me know what you figure out and lets share our info on this bms
thanks
Yeah same here. If you figure it out before me please do share. Controlling the multiplus inverter/charger is straightforward and outlined on the 123 website. I’m going to just try parallel wiring from there to the remote off on the victron mppt and see if it works. If it doesn’t work then I’ll probably just buy the expansion module to make it easy. I have one more night of work and then I’ll be off for 9 days. I can’t wait to dive in and get my system assembled.Interested to see how you figure out controlling the three Victron Items without buying the expansion module? I am in the same situation. This product looks perfect other than only having the 2 relays
