Just watched this video:
I believe I can see the connection you are saying must be soldered by the end user or installer.
Also: The bms requires additional small gauge solid copper cabling to properly connect -- again, you must supply this yourself.
The worst thing about the install process is that teeny tiny dip switches must be flipped several times to properly configure the BMS. And when I say tiny, I had to use my iphone camera as a magnification device. I ended up wearing the switches out just trying to flip them. It's a total mess.
I have the 123SmartBMS. Yes, you do have to solder a wire to the board. This, surely, is a fairly basic electrical skill, mastered in about ten minutes on some scrap wire if you haven't done it before. People use very different sized prismatic cells which will have differing diameter taps on the terminal. If a standard wire was supplied you might find it too small or too large to fit the ring terminal needed to fit the tap.
I've had great before and after-sales support from 123Electric with all my emails being answered thoroughly within 24 hours. My set-up (3rd generation) is fairly new but, so far, is working perfectly.
No, you must use the dip switches. And check out the reviews of the app. For the $$, I really think they should be offering a more solid productJBD Smart BMS seems like a pretty solid budget oriented BMS, and Overkill Solar seems like a pretty solid and straight up seller. Glad you're happy with it so far.
Regarding your impression with the 123BMS, thanks for sharing your feedback/impression. Do you recall what version of their BMS you were using? If the current version still requires soldering and provisioning extra components, sounds like its not very well suited for beginners or those seeking simple systems. But I wonder if these issues have been improved in recent versions? As for the dip switches, could this configuration not be done in the bluetooth app?
I am not sure if this would help or not but it may be in your best interest to try to simplify and clarify your language. GWL is a Czech company I think, English is a second or third language probably, and while I think I understand what you are asking, the above question was somewhat hard to interpret and I am a native English speaker.Hmmmm i was about to buy the 123smart incl a expansion board and relays(48v600a)
I can not speak for 123 electric, but my experience with gwl:
I am trying to get them my to answer my quistion after the figured out that there are things in my shopping cart:
Hello i am...from gwl how can i help you to complete your shopping cart?
My answer 3 times with the description of my system:
Hello can you make my bms complete so it can work as a stand alone? with over and discharge protections?
I think you have either option right? (either directly switch the devices if they are capable or buy the external relay board)It seems also that for every solar charger you must have a different relay??, why not cut the whole pack with one relay?
Or am i completely wrong..
Yes, i totally agree.I am not sure if this would help or not but it may be in your best interest to try to simplify and clarify your language. GWL is a Czech company I think, English is a second or third language probably, and while I think I understand what you are asking, the above question was somewhat hard to interpret and I am a native English speaker.
I means to me that i am close? but i know it needs improvement, i am still working on it.and while I think I understand what you are asking, the above question was somewhat hard to interpret and I am a native English speaker.
I've given up waiting for responses from GWL and have contacted 123 Electric directly. I've been waiting for a response from GWL for 3 days now and I suspect that I will never get a response. I've had other emails to them that they have never responded to. I have yet to be able to get the product working as it is designed to, so hopefully the manufacturer can help to do that, or at least help disagnose if there is a fault.I'm still completely happy with my Generation 3 123SmartBMS and Smart relays. If you have questions it is better to deal direct with 123 Electric rather than GWL. I've always had full answers within 24 hours.
I don't see why you'd need a different relay for each charge controller unless you were exceeding the capacity of the relay (e.g. 100amp). It seems crazy to me to have multiple relays unless you're exceeding the capacity.It seems also that for every solar charger you must have a different relay??, why not cut the whole pack with one relay?
And several boards to attach?
Thanks for the review Nigel - I'll be looking at their offering and Overkill given that i am not the only one having issues with Daly Quality just now.Hi folks. Thought I'd update you on where I'm at with the 123 Smart BMS.
After having used it in my camper for a couple of months now (including a 2 week trip), I actually really like it! I've found it to be very stable (once installed) and has a lot of functionality that I really like! I really like the app on my iPhone and enjoy using it.
Manufacturer
I've had a lot of interaction with 123 Electric (the manufacturers), who have been VERY helpful, fast to respond and extremely pleasant to deal with. I landed up sending them a couple of components that I had problems with. They replaced one of Between Boards (which was faulty) and repaired the End Board (which had had a short damage, which might have been me unknowingly or the reseller?). They did this and posted it back to me from the Netherlands free of charge and very efficiently. The only delay was due to postal delays over Christmas. But to summarise, I can't recommend them more highly as a company. I interacted with Sebastiaan and he was a pleasure - very knowledgable, lots of advise and very friendly. I would definitely consider working with them in future after this experience.
Reseller
I have had very little interaction and response from GWL (the resellers I bought all my gear from), so am still very disappointed with them. Based on my experience, I will not buy from them again and cannot recommend them at all.
General Experience
Apart from the experience of dealing with the companies involved, in terms of the actual hardware, once it's installed it is very robust and has some nice features. It's clear that they are pushing it and improving it as there's already been 3 firmware updates since I installed mine, so clearly they're ironing out issues. I like being able to close the relays in the app to cut off load/charge from the battery. The app is nicely laid out and has some great information in it, like seeing the charge/load currents, etc..
HOWEVER, I probably wouldn't recommend it to a beginner or someone that doesn't have reasonable electrical knowledge. I'm no expert, but I know my way around a soldering iron and electrical installations and I think this is a fairly advanced system to install. For example, to install this BMS onto a 4 cell 12v battery system, you need to solder connecting wires onto all four of the circuit boards and install communication wires between the boards and this installation is fairly intricate and you need to be careful not to short parts of the circuitry. If you choose to get the Smart Relays, then you need to connect even more wires into the circuitry and again ensure you don't short anything.
Value For Money
Is it worth the money? Given that you can buy 3-4 Daly Smart or Overkill BMS for the same money, I'm not sure it is worth the money. I don't think that the "extra functionality" you get with this is worth the extra money compared to a Daly or Overkill. I'll still continue to use is as I have installed it successfully and it's working well, but if I was starting out, I'd probably just stick with a Daly or Overkill.
