$127 - 280ah LiFePo4 Battery Pack Enclosure
bain19
I had originally made this kit for my RV, but it worked so well that I wanted to share it with others. The design has gone through two revisions to get to this point. This kit was created because all the other kits I could find were poorly made, too large or didn't meet cell/battery manufacture specifications.
📏Enclosure Outer Dimensions (L x H x W) 📐
13 ¼" x 9 ⅝" x 7 ⅛"
This kit is excellent because:
✅ It's made in Canada 🍁⛄.
✅ It's made to secure and protect 280aH 3.4volt cells/batteries into a 4s configuration; for larger configurations, multiple enclosures must be purchased.
✅ The enclosure can be grouped and secured together using threaded rods to become easily expandable and modular.
✅ The enclosure can be stacked vertically to allow for mounting in small spaces. Limit stacking to two enclosures high.
✅ The enclosure incorporates side handles for easier movement.
✅ It was designed to secure Grade A cells/batteries and provide a source of slight compression.
⚠ That also means that the installer or owner should be careful to not over-tighten the fasteners. If cells/batteries are bulging caution must be taken as poorer quality Grade B cells/batteries will have difficulty fitting.
✅ It's made with high-quality 3D printed plastic and designed for strength.
✅ It can be installed in trailers, campers, RV's(away from heat sources), in most dry locations and other power center solutions.
⚠ Do not install environments that get hotter than 40°C or 104°F or in wet environments.
✅ It comes with pre and post-sale technical support.
⚠ This kit does not come with or include LiFePo4 cells/batteries. Purchaser provides their own.
📃 Purchaser assumes all liability in the event of damage or injury to self, others or property.
Link to the kit can be found here
RB Cooper
Ok looks intriguing, just sorry there is no provision for mounting a BMS. Are any of the threaded 1/4" rods and end nuts/washers supplied with the kit?
