Rocketdawg
My system is hybrid with 5kw of Mitsubishi panels, Schnieder XW6048, two MPPT charge controllers, and I recently updated the lead acid forklift forklift battery to a 12p 14s Leaf pack. I built the fire resistant cabinet which is lined with cement board and well sealed. I do not run a bms yet. All cells are testing spot on.i can charge them at 100 amps for hours with no heat rise. I have the charge controllers set to 3 stage float at 57v max. Once the bulk voltage is reached the float setting takes over to maintain a full charge until the sun goes down. Minimum voltage on the invertor is set to 46v. I have been running my entire home on it for up to 6 full days at a time before the clouds force me back on the grid. We have electric hot water heater and clothes dryer. We wash clothes in sunny days when the batteries are near full with no dirty clothes left and plenty of hot water for showers and dish washing. I cut my electrical usage from 1200kwh per month to under 300kwh the first month on these leaf batteries. I could never have done that with the old forklift batteries. Some day I would like to double the pack size, make a few tweaks in the house, add my 2kw wind generator and install a backup Lp water cooled generator which will heat my shop floor. All in good time! But at least I'm on my way!
