Rumbaar
I purchased 4 x 3.2v 320ah cells via AliExpress (tried to find a high rated seller with a good score). I've gotten a Daly 250a BMS.
On initial setup, I put into 4S and charged to capacity with a 14.6 40a charger. I did a capacity test and via a shunt recorded only ~289ah of capacity. I then when back to the order and have now seen that when I click through to the item, the store has change it to 280ah cells. The QR codes on the cells aren't in a format that can be used to determine build, date or capacity.
I've since charged again, setup in a 4P configuration and top balanced them to 3.6v. Reconfigured back to a 4S configuration performed a load test (10-13a draw) and gotten ~290ah of capacity till the BMS shut down at ~10v.
I've gone back to the seller, for a please explain.
But my question, is there something I am doing wrong and should I expect to get 320ah capacity for the type of test I'm running?
I had gotten a Daly 5a active balancer, and now have connected that up and trying a 3rd capacity test to see if that'll help (currently charging the array).
