This is a vehicle-mounted system. This is strictly a question about the battery-alternator interface.
TLDR: Question: Has the issue, of a high-drain (dead short) by the LFPo 12v 100ah batteries, been resolved? I.E. so the BMS restricts the charging rate to something reasonable like 20-40 amps. So a DC-DC converter isn't needed, to interface between the alternator and the 12v LFPo.
Intro: My main system is backed by 2x EG4 5kw LFPo's. Growatt 3k. 1800w panels. 3kw gasoline generator.
I left the existing 12v Flooded Lead Acid, 1kw modified sine wave inverter, and basic 12v chassis stuff, alone. I added a simple NOCO-brand 5amp charger, along with a basic mechanical 120v AC plug-in wall-timer, that periodically cut's it's power, so the charging cycle will reset.
The problem is, FLA is junk. The 12v Group 27 Marine batteries from East Penn State (O'Reillys 27-DCM) consistently die after 3-4 yrs, and I want to swap them out with maintenance-free LFPo.
Right now, there's a single house 12v battery, and an engine start battery, and there is a flip-flop no-drain solenoid that can be toggled to disconnect them from each other. Can I just get 1x 12v 100ah Ampere Time, or other brand (please state!), to replace the house & engine start battery? The draw is 300amps max, from the engine's starter, according to what documentation I could find. Of course, that's only for a brief period, but on cold starts after a long sit, there could be many seconds of turning it over.
The thing that held me back from converting everything to LFPo, was the issue with the legacy alternator needing some DC-DC converter to the LFPo. That seems retarded, and I wonder if it's been solved?
