12v lifepo4 x 2 problem.
JulianG
I have 4 x 280ah 12v home built lifepo4 batteries.
I now want to combine 2 of the batteries to give me 24 v but don't have the room to make 1 battery easily.
Can I join to sets of 4 cells each with a long bus bar or better heavy cable 25cm long? Then use 1 new 8 cell BMS.
It's on a river boat so need 12v for general use bow thruster lights electric loo ect so I use 2 x 12v batteries in parallel. I then need 24v for kitchen induction hob and and 900w combi oven electric drive with a lynch motor.
If I flatten the batteries I do have a panda generator as back up as well as a 100a alternator.
My current BMS are 200a 12v and can't be used in series.
Or can Anybody recomend a BMS for series use?
JulianG
Thank you will take a look.
Having drilled down into my BMS it looks like I can attache them in series But the supplier stated "we don't recomend it" without clarification. Not sure what the down side is of having 2 x 12 in series v 1 x 24v.
FilterGuy
What, me worry?
Los Gatos CA
The primary issue of having 2 x 12 is that there is nothing to keep the two in balance. However, if they are decent cells and properly set up, this should be a minor issue. The second thing is that with 2x12 there are two BMSs and therefore twice the possibility of a BMS failure.
JulianG
So the benifit is when charging, if I de couple, using 300a relays, the two 12v batteries I can charge them from my generater or my alternator as 12 v batteries. When I need to use them the relays will join them back up.
JulianG
This is one of my 4 batteries. 2 of which I transport home and power my lawn mower then charge via solar and when not mowing use to them to power one ring main in the house.
Goboatingnow
the general answer is yes you can do as you say , whether you can one BMS or two is largely a personal choice issue
Mickrobb
Don’t buy the jk bms, I brought 3, 12v bms and 2 failed
