Hello everyone,
Not solar related this time but a 12v/battery question. I have an awning motor on my fifth wheel that doesn't like to work all the time. The awning will extend the awning fine but retracting the awning will cause it to stop. I have to wait a few minutes before I'm able to retract again. The motor will only retract about 1-2 feet then stop again. I have to keep this pace till the awning is completely retracted.
I thought the battery was going bad so I bought two Interstate SRM-27's and hooked them together to get 12 volts. This solution worked perfectly for the first few times but I'm back to the same situation with the awning motor. I have noticed that the stopping and starting of the awning motor happens if I'm running other 12v volt appliances in the Rv such as the 12v lights. Does it sound like a charging issue? After joining and learning about solar and batteries I'm thinking that maybe its a battery balance issue? Should I try just running one battery to see if the symptoms continue? I have a meter so I can check voltage but I do not know what the correct voltage range should be.
Any help or suggestion are welcome,
Thanks for the help~
