justinm001
- Dec 18, 2022
- 1,516
You should get yourself a kill-a-watt and plug your devices in to get your real world wattage. Higher volt systems are cheaper overall and less headache. 24V if possible and if you're going dc-dc charger then just get 12v to 24v one.
I'm assuming you're talking about lithium batteries and not lead acid, right? If lead acid you could likely just add a switch/relay and connect them directly into the alternator. Another idea is to add an alternator to your engine then get a wakespeed ws500 type regulator so you can set it to charge the batteries if you have lithium.
If going 12V you might be able to just get a ws500 and connect it to your existing alternator and it has an option for a switch so you could possibly setup a switch where it'll change between charging your van and your inverter batteries. I'm imagining you being able to turn on inverter charge mode then the ws500 switches every 15 minutes between charging the house batteries on a lithium profile then back to the starter battery on a lead acid profile connecting each battery using relays.
