I bought 4, 300 watt split cell solar panels. They run at 33 volts, 9.2 amps. My goal is to run a 700watt air conditioner in an RV during the day and a few hours after night.
I bought them without realizing I would need such a large MPPT charge controller. It seems at 12v that I need at least a 150v and 100 amp charge charge controller which tends to run 400-600. I can also go with a 24v and could use a 50 amp charge controller. But then I need a 24v battery pack. I'm probably going to supplement the 1200 watts with a few 200 watt panels, but those will likely be on a seperate charge controller.
Option 1, 100amp charge controller, 12v 280ah diy lithium pack
Option 2, 50amp charge controller, 24v 2, 100ah diy lithium packs, or maybe 2, 280ah packs.
I think cost wise it makes the most sense to bite the bullet on an expensive charge controller and thick 12v wiring.
What would you do?
What would you do?
