Hello,
I'm building out a new system for a sailboat. Most all of the components in question are 12 volt.
The 12 volt users are Autopilot, chart plotter, lights, water pump...standard stuff.
Except for the largest draw - the air conditioners are 24 volt. They are the new Zero Breeze units which use 250watts each.
The Air Conditioners draw more power than everything else on the 12 volt side when they are on.
Would it be more efficient to
1. build out a 12 volt system and convert to 24 for the AC units
OR
2. build a 24 volt system and convert to 12 for the rest of the house
AND why?
The whole system is not terribly large. I was planning on 400 watts solar using a 200 amp hour battery. Not bad considering the high Air Conditioner loads will be in the middle of the day when the sun is strongest.
We will also have a 2000 watt inverter consuming DC as well but all the components will be within five feet of eachother.
Thanks
OR
AND why?
Thanks
