DIYSolarShed
- Oct 5, 2020
- 46
Hello all,
I am trying to terminate 12x total 100W panels into a Sol-Ark 12K. Panels: https://www.amazon.com/RICH-SOLAR-Premium-Monocrystalline-Solar/dp/B086ZL9PM8
4x of the panels are ~155ft from the Sol-Ark, while 8x of the panels are about ~120ft away. (See Diagram)
The 4x and 8x panel groups will be shaded at somewhat different times of the morning (until 9:30AM and 10:45AM). I am open to using a Midnight Solar combiner box or similar if that would be an optimal solution. The panels advertise that they include "bypass diodes."
Alternatively, I am open to using lower AWG wire to terminate the panels directly into the Sol-Ark. Using this calc I think that's possible even with the 155ft: https://www.calculator.net/voltage-drop-calculator.html
The Sol-Ark seems to indicate a minimum MPPT voltage of 150V. It seems that 4x of the Rich Solar panels would not hit the minimum, but 12x would.
Ultimate Question:
1) Should I terminate all 12x panels into a combiner box, or (because of the shading) is there a benefit to running the 4x and 8x groups with separate wires into each of the two "Solar Strings" that Sol-Ark provides on each MPPT? (Technically 2 full MPPTs and 4x or 6x Solar Strings per Sol-Ark).
Ultimate Question:
