Yes they are not ready for pouring.I see daylight under the closest form, sloppy concrete bleed expected.
My foundation is pier & grade beam, so dirt erodes and lets in water and rodents.
Is that dirt actually compacted per proper engineering of earth?
Home depot I think. It's aluminum and called a "service entry".If you don't mind me asking what brand LB Conduit is that in your first post and what size?
Yes I probably will take another crack at leveling, was a bit tired when I knocked off last night.Can you take a digging bar or flat shovel and trench out the forms? I wouldn't bother digging out the middle. I would just dig a 2" wide little trench with a tool just enough to level the form boxes on one end. If not digging out the middle, it would result in less concrete poured or mass, but not by much. If you want to do more digging, dig out the middle too if you want to keep the volume/mass of concrete. I think you'd be happier with level forms so you can screed the tops with a board across the tops of the forms. I fear that unlevel forms is going to probably just cause more heartburn in the future, maybe multiple times.
Put them dogs on it! They'll knock it out in no time. Just pay em with bacon. Be careful though. They might unionize on ya.Yes I probably will take another crack at leveling, was a bit tired when I knocked off last night.
Design has 2 #4 rebar through the post base. ?When ever I set post --- I always hang my post where the concrete goes underneath the bottom of the post-- Over time if you don't do this ,they'll sink right through the concrete -- Since you're using steel post, you can also run a rod through the base of your post
3x sunny boy 3.8kwForgive me if you've already stated, I remember seeing your batteries, but what inverter(s) are you planning to install and use?
Didn't think of the Line snapping.that line needs to be covered with a tarp. Even with the wire mesh. Glad it worked out.
