I've continued to cycle the batteries pretty much every day, running 2 at a time in parallel. I've been charging to 14.1v and then recharge once they consume 544Ah (272Ah x2). They are typically getting close to 12v at that point, so they seem like they have full capacity without hitting the steep drop under 12v.
I started working on my other 3 battery boxes today. The main cages are all welded up, I just need to do the compression bars and the panels. Next weekend probably. I'm not in a rush, my van delivery is delayed.
I decided to go ahead and capacity test all my individual cells. I have a tester, but it won't operate any higher than about 6.5a. That will take ~2 days per cell, so it will take at least a month for all 16 if I can keep them running continuously. Maybe my van will be built by the time my cells are fully tested.
My old harbor freight abrasive chop saw is dying, so I used it as an excuse to buy one of these evolution saws that cuts steel with a carbide blade. I have never used one and it takes a leap of faith to bring the blade down on the steel material for the first time. It cuts steel almost like it is a piece of wood. I tried it with some thick walled tubing and it cuts through in a few seconds. You get little chips instead of the metal dust you get from an abrasive blade, so it's still messy, but the cuts are super clean and precise and the part isn't hot after cutting. It made cutting all the angle for the battery boxes go really fast with much more accurate cuts.
