manly
- Jun 23, 2021
- 20
I noticed the specs on the Victron 3000 Watt too about significantly less capacity with higher temps. Like you, I'm hoping to be able to juggle loads to keep everything going. My biggest loads are a washer/dryer combo, the A/C, and microwave. Would also like to be able to do induction cooking. Obviously something has to give!
If worse comes to worse I'll purchase a 2nd 3000VA Victron inverter, parallel them, and problem solved.
For your DC low battery disconnect, I've been thinking about that (you've obviously thought this through very well) and wondering if perhaps that isn't necessary in my case as the BMS will disconnect the batteries if they got too low. But perhaps not relying on the BMS is best? I'm probably missing something here. Let me know, and thanks again for sharing!
