PictureMeFree
- Oct 27, 2020
- 19
Hi all,
I am installing a Giandel 24V 2000 watt inverter into my camper van, and I am attempting to install a gfci circuit. The problem is that I’m getting 140 volts at the 2 outlets (gfci is first outlet in the circuit and feeds a 2nd non gfci outlet).
The inverter is supplying power to a circuit breaker box, and the multimeter reading coming out of the inverter outlets, at the hot and neutral busses in the box, and between the circuit breaker hot screw and box’s neutral- all read a perfect 120v. So, the issue is occurring between the circuit breaker and the outlets.
Does anyone know what could be causing this? I have ensured all connections are very tight and secure.
Also worth noting- the neutral and ground wires are bonded to one bus in the breaker box. Giandel told me there is no neutral/ ground bond inside the inverter and that I would need to bond neutral and ground in order for the gfci to function properly. I suspect something here is causing the issue, but again, the voltage reads 120 at all points inside the breaker box. It’s only high at the outlet terminals.
Thanks in advance for your experience and advice.
