treetrnk
I have a 8s 24v 280AH lifepo4 battery made with eve cells. As far as I can tell it is working great, but I can never get the BMS to work correctly. I'm already on my second.
The first had a loose connection which I'm pretty sure fried the BMS. It worked, but would shut off when the inverter was pulling more than 4 amps from it. I fixed that loose connection (and tightened all of the other connections to make sure) and I got another 150A Daly smart BMS.
The new one worked for maybe a month, but it started randomly complaining that the cell voltage was too high and would shut off. When it does this, it is usually cell 5 or 6 that are too high, and it will say one of the cells is over 4v. However, if I unplug the BMS and plug in my cell balancer instead, it says that all of the cells are at normal voltages, somewhere in the 3-3.6v range. Then, when I plug the BMS back in, all of the warnings are gone, and it gives the same cell voltages that the cell balancer did. I have also checked with a voltmeter when the BMS is plugged in, and the BMS is wrong.
This would happen once or twice a week, and I thought maybe it was humidity causing the issue. I live in a converted school bus, so humidity is a problem, especially where I live in Pennsylvania, USA. Recently, the problem has gotten worse. It will complain that cell six is over 4.2v and cell five is under 2v. And it's happening multiple times a day, especially in the middle of the night. Last night I think it happened 5 times.
So my question is, did I just get another bad BMS or is it possible that this is being caused by humidity? Is there anything else that might be causing the issue? Thanks for the help!
