PhotonFire
- Oct 22, 2021
- 18
Did you or do you top balance your cells? Some alligator clips would work but I dont have 64 of them available, not even 32 or even 2.
I noticed the terminals extend past the cell cases, so I am thinking about laying out a strip of aluminum foil and standing them up vertically in parallel on top of the foil strip. Then I would make a strip for the top as well and lay it across the top of the cells, maybe putting a coin on to each cell to weight down the top aluminum stip. Maybe a strip of cheap kitchen foil can only carry 1,2, or maybe 5 amps but I think this should be enough to balance these new cells when they are charged to 3.65V?
Jumper wires are an easy way to top balance these before they are spot welded, but no bolt on terminals means we don't get to switch from parallel to series and back for a top balance. Going to have to trust the BMS.
