Johannlog
The sun shines even on cold days
- Apr 28, 2021
- 99
My understanding is that using 2x 40A SCCs I should not exceed 100A charging input.Okay, thanks for all the advice and sharing your knowledge....
I've been doing more research and reading as suggested; I think I better understand the components now.
Here is my plan, let me know if you think it will work or if I should make changes.... I'm more concerned about making a solid system than saving a few $.
Here's what I'm planning to make.
2x 40Amp Renogy SCCs (already have these)
I'll connect these to a DCC-300HB Chargery.
I'll connect my 4,000w 24V Giandel (6,000w surge) Inverter to the DCC as well. The inverter will power my 100A house panel.
The DCC will be connected to the Chargery BMS8T-300 which will be connected to16x 280AH (Amy's EVE) Matched cells, (with 300A fuses). (2P8S configuration of the cells)
My understanding is that I can connect 16 cells to this BMS
But I might be wrong on this.
Planning to use 8x 315W panels (4 panels per 40v SCC). 8x315w = 2520w ÷24v = 105A
I think I'm calculating this right.
