16s BMS , ask for recommendation
jwwh
Hi, i was looking some affordable BMS recommendation, below are the criteria must be meet.
1.) 16s (LiFeP04) 48v system
2.) MUST be 250a or above (anything above 200a seems hard to find)
3.) need to be smart BMS able to access thru bluetooth or other connection.
*I don't want to use DALY BMS, as daly report alot of problem and it is only start balancing when charging.
I'm in the same boat and i found the following BMS on Aliexpress.
JBD 16S 48v Smart bms 300A.
